April 4, 2015, 17:33 |
Laplace Eqn. Finite Diff. Error Problem
Gorkem Ocalan
Rep Power: 11 |
I have some problems about error analysis of Laplace Eqn. in 2D. I generated coefficient matrix and right-hand side vector as Au=b format properly and solved u=A\b. I calculated analytical solution with respect to boundary conditions which are u(x,0)=0 ,u(x,1)=x-x^2, u(0,y)=0, u(1,y)=0. There is a problem about error. I was expecting to observe the decrease in error by making the mesh finer. But it did not happen in that way. 41x41 mesh gave better error result than 81x81 mesh. I also attached the code (MATLAB) for the people who are interested in. Thanks for your concern... |
April 4, 2015, 17:46 |
Filippo Maria Denaro
Rep Power: 71 |
indeed, the error must diminuish ... how do you invert A? check if A*A^-1 is the identity matrix (note that u=A^-1*b)
Check also the exact solution |
April 5, 2015, 01:06 |
Alex
Rep Power: 12 |
Be careful with MATLAB. Its matrix operations don't always work the way you'd expect.
Eliminating exchange energy between phase in Granular Temperature diff eqn. | cfdbusiness | FLUENT | 0 | February 2, 2010 22:30 |
Finite volumes vs. finite elements: applications | Lionel S. | Main CFD Forum | 10 | January 22, 2007 10:51 |
Laplace operator in finite element formulation | Rafael | Main CFD Forum | 2 | October 19, 2004 21:09 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
