DG introduction
Like Tree3Likes
  • 1 Post By Rami
  • 1 Post By panou
  • 1 Post By cfdnewbie
Old   May 23, 2008, 13:30
Default DG introduction
John
I'm familiar with CG well (and FVM as well), but I do not have any knowledge about DG, can anyone suggest me a suitalbe an introductory reference (brief that gives concept)
Old   May 23, 2008, 15:20
Default Re: DG introduction
Jed
I like the sections on DG in Karniadakis & Sherwin `Spectral/hp element methods for CFD'. For elliptic problems, there are several inequivalent approaches with different stability, consistency, and computational properties. Arnold and others 2002 `Unified analysis of DG for elliptic problems' is a good start, but somewhat technical.
Old   May 23, 2008, 17:47
jinwon park
B.Q. Li, 'Discontinuous Finite Elements in Fluid Dynamics and Heat Transfer', Springer 2005
Old   May 25, 2008, 09:13
Rami
John,
I have received lecture notes from Bernardo Cockburn (cockburn@math.umn.edu), one of the major players in this field. You may contact him directly, or else send me your email and I'll forward it to you.
ami
SKKhan likes this.
Old   May 25, 2008, 09:28
John
please forward a copy to me (john.dongarra@gmail.com), thanks.
Old   May 25, 2008, 09:45
Rami
Please find it in your mailbox.
Old   May 25, 2008, 11:27
John
Thank, but what you sent to me is not a Lecture note, but is a review paper, which is not useful for starter!
Old   May 26, 2008, 09:45
Rami
Well, this is what I had from him. As a last help I can offer, have a look at this ppt presentation: www.iacmm.org.il/ISCM20/DGM_ISCM20T.ppt
Hopefully, this will be helpful.
Old   May 26, 2008, 12:22
John
Thanks for your knid effort.
Old   May 27, 2008, 02:23
Rami
You are welcome. If it does not serve your need, the cats pictures at least are cute...
Old   August 2, 2011, 03:20
Shahzada Khurram
SKKhan is on a distinguished road
Originally Posted by Rami
;55274
John,
ami
please forward a copy to me (shahzadakhurramkhan@gmail.com), thanks. as soon as possible because I am studying the Book "Discontinuous Finite Element For Fluid Dynamics and Heat Transfer" by Ben Q.Li. I think there are typing error so give the any useful material about DFEM. I am very thankful of you.
SKKhan is offline   Reply With Quote
Old   August 2, 2011, 03:25
cfdnewbie
cfdnewbie is on a distinguished road
I've found the Book by Li not very good... why not try the Hesthaven book (has become standard in the field) or Kopriva's DGSEM? I find both of them to be much more readable as well---
cfdnewbie is offline   Reply With Quote
Old   August 2, 2011, 03:29
Shahzada Khurram
Book Name and Author Name DGSEM
Old   August 2, 2011, 03:33
cfdnewbie
sir, yes, sir!!
http://www.amazon.com/Nodal-Disconti.../dp/0387720650
http://www.amazon.com/Implementing-S.../dp/9048122600
Old   August 2, 2011, 07:34
aaaaaaaaaaaaaa
panou is on a distinguished road
For more and advanced information on modal DG method you can look the thesis of Landamann:
http://elib.uni-stuttgart.de/opus/vo...9/pdf/diss.pdf
Also, if you want to understand very well the dg method you must read by books or papers the below matters:
1.Schemes of finite volumes theory (due to relation of dg with finite volumes (discontinuity at interfaces-fluxes))
2.Riemann solvers (mainly approximate Riemann solvers)
3.Spectral & high order Elements
SKKhan likes this.
panou is offline   Reply With Quote
Old   August 2, 2011, 09:25
Shahzada Khurram
thanks I will Study these materials about DG.
Old   August 2, 2011, 12:38
cfdnewbie
Well, in my opinion, most people nowadays tend to use nodal DG schemes, at least from what I know about some of the "big players" in the field.... but modal sure has its own advantages, so it's good to know at least the basics....
I'd still recommend DG SEM by Kopriva for a beginner...
Regarding the Riemann solvers: that depends on what you want to do with your code....
for well-resolved problems, the Riemann solvers shouldn't really matter at all, but for underresolved probs, I agree...
Cheers!
SKKhan likes this.
Old   August 2, 2011, 16:18
aaaaaaaaaaaaaa
The choice of Riemann solver play important role for DG formulation. Is the way that an element derives information by neighbour elements.
Mainly for solutions with large gradients or discontinuities(such as shocks)
the Riemann solver is crucial part due to the resolution of solution at these regions.
Old   August 2, 2011, 16:32
Wink
  #19
cfdnewbie
Hello panou, I tend to half-disagree with you )
Sure, Riemann solver couple the system, but due to the higher polynomial approximation in the cells, jumps at interfaces tend to be much smaller than for FV... Thats why you can get away with using a cheaper Riemann solver than FV. In fact, as long as you are decently resolved, lax Friedrichs is ok most of the time!
Regarding shock capturing: shocks on coarse grids are generally not captured at the grid cell interface, but within the cell!! And thats done by stabilizing with viscosity, not by the Riemann solver.
So, as you see, in DG Riemann solvers play a less important role than in FV!
Cheers!
D. Choudhury. Introduction to the Renormalization peiyong FLUENT 15 September 29, 2016 23:08
Introduction to CFD TerryPrice Main CFD Forum 3 March 30, 2010 07:48
Organization of "Introduction to turbulence" Jonas Larsson CFD-Wiki 3 September 2, 2007 12:24
Free UK seminars: Introduction to CFD Gavin Butcher CFX 0 November 23, 2004 09:16
General Introduction about STAR-CD wanted! Jason Siemens 3 February 16, 2000 07:07
