How to decide PDE type for 1st order scalar PDE's |
June 7, 2008, 14:34 |
Re: How to decide PDE type for 1st order scalar PD
#21 |
>I don't see how the Richardson iteration corresponds to a steepest descent. What is the relation between the direction of the residual and the steepest descent direction?
it is very clear: assume grad J = G steetest descent iteration is like this x_new = x_old - alpha G, alpha is computed from line search my previous problem is match with this structure if we use explicit time stepping but it does not have line search, the formal method is to use implicit time stepping to prevent divergence, note that this method is very common in literature of image analysis (differential geometry), but I could not find any convergence theory. your statement implies that the Laplacian operator is not a infinite dimensional smoother, but i think there should be some theory, at least stablisihng minimizing sequence, if u have further comment please continue, elase thanks for your contribution. |
June 22, 2008, 22:20 |
#22 |
Hi Vinayender, thanks for your replies. I studied all responses and referred some books. here is what I concluded.
1. 1-D Hyperbolic problems need initial condition (at t=0) and boundary condition (say at x=0) but not necessarily closed one. (Please refer eg. 3.1 from Laney's book on computational gasdynamics). 2. for first order scalar PDE's, sometimes we don't need boundary condition if input function is a wave as here boundary condition is implicitly defined (no need to explicitly provide any boundary condition). 3. Explanation given in Laney is what I was looking for. so according to it, all first order scalar PDE's will be hyperbolic as they will be time marching (or which ever variable is your y axis). Same has been said by Mr. Tom in his reply to this post. I agree with him. Thanks again. regards, Shantanu. |
June 22, 2008, 22:22 |
#23 |
Hi Jed,
thanks for your replies. I studied all responses and referred some books. here is what I concluded. you are correct that classification makes sense only for linear PDE's. 1. 1-D Hyperbolic problems need initial condition (at t=0) and boundary condition (say at x=0) but not necessarily closed one. (Please refer eg. 3.1 from Laney's book on computational gasdynamics). 2. for first order linear scalar PDE's, sometimes we don't need boundary condition if input function is a wave as here boundary condition is implicitly defined (no need to explicitly provide any boundary condition). 3. Explanation given in Laney is what I was looking for. so according to it, all first order scalar PDE's will be hyperbolic as they will be time marching (or which ever variable is your y axis). Same has been said by Mr. Tom in his reply to this post. I agree with him. you can check it. Thanks again. regards, Shantanu. |
June 22, 2008, 22:27 |
#24 |
Hi John,
thanks for your replies. I studied all responses and referred some books. here is what I concluded. 1. 1-D Hyperbolic problems need initial condition (at t=0) and boundary condition (say at x=0) but not necessarily closed one. (Please refer eg. 3.1 from Laney's book on computational gasdynamics). 2. for first order scalar PDE's, sometimes we don't need boundary condition if input function is a wave as here boundary condition is implicitly defined (no need to explicitly provide any boundary condition). 3. Explanation given in Laney is what I was looking for. so according to it, all first order scalar PDE's will be hyperbolic as they will be time marching (or which ever variable is your y axis). Same has been said by Mr. Tom in his reply to this post. I agree with him. 4. The PDE given in this post is also hyperbolic rather than both hyperbolic and parabolic. Explanation to this is that in a parabolic PDE, disturbance at a point is felt in both forward and backward directions but if we see in this problem (linear advection equation or first order wave equation), disturbance at a point is felt only in forward direction, which is nature of hyperbolic problems. Thanks again. regards, Shantanu. |
June 22, 2008, 22:29 |
#25 |
Hi Tom,
thanks for your reply. I studied all responses and referred some books. here is what I concluded. 1. 1-D Hyperbolic problems need initial condition (at t=0) and boundary condition (say at x=0) but not necessarily closed one. (Please refer eg. 3.1 from Laney's book on computational gasdynamics). 2. for first order scalar PDE's, sometimes we don't need boundary condition if input function is a wave as here boundary condition is implicitly defined (no need to explicitly provide any boundary condition). 3. Explanation given in Laney is what I was looking for. so according to it, all first order scalar PDE's will be hyperbolic as they will be time marching (or which ever variable is your y axis). Same has been said by you in your reply to this post. I agree with you. Thanks again. regards, Shantanu. |
June 22, 2008, 22:57 |
#26 |
Hi Jed,
#27 |
Hi John,
June 22, 2008, 22:58 |
#28 |
Hi Tom,
June 23, 2008, 12:48 |
#29 |
Thanks.
Instable natural convection case | Peter88 | OpenFOAM | 5 | August 18, 2011 01:23 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
buoyantSimpleRadiationFoam | msarkar | OpenFOAM | 0 | February 15, 2010 06:22 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
Flow Around a Cylinder | ronaldo | OpenFOAM | 5 | September 18, 2009 08:13 |
