how to simulate the conduction without meshing the wall layer
Old   May 18, 2015, 09:53
Default how to simulate the conduction without meshing the wall layer
buidu
buidu is on a distinguished road
I am runing a simulation on the convective heat transfer on a cylinder. The cylinder is made of almunium and has a thickness of 30mm. It has a constant inner surface temperature of 40 degree. I want to study heat convection on the outer surface. Can I use shell conduction here? And how should I make the setup? Thank you for your answer.
regards,
Hao
buidu is offline   Reply With Quote
Old   May 18, 2015, 10:19
jpando is on a distinguished road
Which software are you using to simulate this problem?
This will determine how you will set it up.
jpando is offline   Reply With Quote
Old   May 18, 2015, 14:27
buidu
I am using fluent...
Old   May 18, 2015, 16:26
Fluent has an option for the boundary to enable shell conduction where you specify a thickness and material. The Thickness of the shell will be out of the fluid region unless you specify shell conduction on an internal-wall. Then the layers will be between the boundary and its shadow.
To specify a temperature, I think you turn on shell conduction and the temperature you input will be on the outer surface of the shell. I am not completely sure about this and you may have to refer to the Fluent User Manual to make sure that's correct.
If that doesn't work you can specify a convection boundary condition on the wall at the temperature you want with a very high convection heat transfer coefficient.
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
Wall coordinates and boundary layer thickness bentmol Main CFD Forum 1 July 3, 2011 20:44
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
