June 7, 2015, 09:13 |
VOS = C_MU_L(cells,thread_cells);
Rep Power: 13 |
i used the DEFINE_ADJUST to adjust the viscosity of the material. However, when the "C_MU_L" occurs in my UDF, it will make mistake as followings:
Error [cortex] [time 7/30/14 15:49:6] FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. No matter how simple the UDF is, if the "C_MU_L= " occur, the error will appear. do you know the reason why it happens? |
