July 8, 2008, 02:08 |
Water turbine CFD modeling
I'm trying to model a turbine that is submerged in water and water is flowing with a speed to rotate the turbine. My objective is to find out the torque generated. My questions: 1) should I use global rotating reference frame or MRF? 2) should I take the torque when it's rotating or when it starts to rotate? I did a CFD on wind turbine before, using global RF rotating the fluid (air) surrounding the wind turbine blade and calculated the lifting force on the airfoil. But I'm not sure if this is the correct approach for the water turbine. Thanks for any help/reply Peter |
July 8, 2008, 11:44 |
Re: Water turbine CFD modeling
Dear Peter,
You can model the turbine. You should be aware which turbine you are modelling. Radial, Axial or Mixed Flow. In case of Francis Turbine, you can calculate the torque on the blades if you are simulating the system on Ansys CFX 11. And in this case runner is always rotating with a stationary frame of reference. I hope you get it Regards, Amit Roghs |
July 8, 2008, 20:21 |
Thanks for replying
Mine is axial turbine flow. Did you mean that I should apply rotational velocity to all the blade surfaces and also the fluid region surrounding it? I saw a centrifugal blower tutorial in Fluent manual, fluid and blades are rotating in the same direction inside the MRF. Is that what you meant? Thanks again for helping |
April 22, 2010, 22:50 |
#4 | |
yashwant
thanks -- |
April 4, 2016, 02:31 |
mortezasekaloo
Rep Power: 10 |
Hi
I am a student of fluids and I like your site very much. I am researching on how to analyze Francis turbine. In visiting your site I noticed about the analysis of these turbines. I want to ask if you can, please help me about the procedures analysis of Francis turbine with full details. Thank you so much |
August 8, 2008, 03:24 |
my promblem is desgin modeling in water turbine (pelton , frain kaplan etc turbin )which software is used
August 25, 2008, 06:26 |
Hi Dushyanth,
What do you want model? can you send me pics so that i can suggest. Sam |
February 19, 2010, 16:22 |
Shane Staunton
hey peter, im modeling a 3d axial tidal turbine too-im only new to cfd so if you could give me a couple of steps to help get me started thated be brilliant?! i have my geometry made up and all!
cheers bro |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 17:09 |
Meshing Volume in Gambit for a water turbine | Zaqie | FLUENT | 1 | July 24, 2009 01:25 |
water jacket optimization using cfd. | meh_wj | Main CFD Forum | 0 | December 17, 2007 04:20 |
ASME CFD Symposium - Call for Papers | Chris Kleijn | Main CFD Forum | 0 | September 25, 2001 10:17 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
