August 4, 2008, 11:10 |
stationary discontinuity
What is stationary discontinuity how is it different from contacts and shocks
August 4, 2008, 11:13 |
Re: stationary discontinuity
A stationary shock is one example of a stationary discontinuity. Since shocks and contact surfaces can be moving through a fluid, the 'stationary' descriptor is prepended to denote the type of discontinuity being referenced. This also applies to other types of discontinuities.
August 4, 2008, 11:19 |
Since the classical laws of physics must be Galilean invariant, we can use any uniformly moving reference frame to describe the physical phenomenon. How does one define a stationary discontinuity in that case ?
August 4, 2008, 12:33 |
Stationary is a name then.
What about if this discontinuity is a contact wave i.e. one eigenvalue for a system of conservation laws is it still a stationary discontinuity then? |
August 4, 2008, 14:42 |
Generally no. The eigenvalue typically corresponds to the speed of the discontinuity.
velocity in stationary frame | Alaa Hassan | CFX | 4 | August 24, 2021 03:59 |
solid-liquid discontinuity contour | tantular | Main CFD Forum | 0 | March 10, 2010 03:57 |
How to output data from stationary part only? | Aerolex | FLUENT | 0 | November 16, 2009 22:46 |
Rotor stator problem: Discontinuity across the interface | Bubka | CFX | 2 | November 11, 2009 07:57 |
Stepwise Discontinuity problem | Alan Kang | Main CFD Forum | 1 | February 22, 2000 23:46 |
