July 1, 2015, 11:03 |
Lift and Drag
Rep Power: 10 |
Hi guys,
i want to calculate lift and drag forces and their coefficients for an airfoil.. i will use SST for turbulence model but i do not know how can i calculate lift and drag.. i request your suggestions.. Thank you.. |
July 2, 2015, 13:10 |
Anthony McCarthy
Rep Power: 11 |
What Software are you using? If your are using fluent you have ?two? options:
1) You can use the Cl & Cd monitors, under the monitor tab in the solution section, here you can create a monitor as to view coefficients of lift and drag. 2) At the end of the simulation, open the report>Forces, use x=0, y=1 and vice versa, using your angle of attack and force information it is possible to calculate your lift,drag and coefficients. |
July 3, 2015, 07:47 |
Rep Power: 10 |
First option looks like easier but can i calculate the lift and drag forces by using this option? Actually i can calculate manually this forces after finding coefficients but i want to calculate it with fluent as you know
Thank you |
July 3, 2015, 10:17 |
Anthony McCarthy
Rep Power: 11 |
No.1 may be easier to obtain values for one angle of attack as do not forget you will have to change the x and y values to the sin and cos values for the given angle of attack.
if you are running many simulations, different angles of attack i find obtaining the forces in x- and y-direction as the most simple as i can then just load the forces into an excel sheet created that will calculate the lift, drag, Cl and Cd all in one go and saves hours overall! |
July 4, 2015, 09:16 |
Rep Power: 10 |
Thank you dude i got it
April 10, 2018, 01:16 |
#6 | |
Ram Arvind S
April 10, 2018, 17:04 |
Matt
Rep Power: 17 |
If you have total pressure and viscous forces on the body in X and Y directions, sum each axis and use this:
http://www.aerospaceweb.org/question...cs/q0194.shtml If you have pressure and shear distributions then you need to use this: http://web.mit.edu/16.unified/www/FA...ctures/f03.pdf |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
[OpenFOAM] Display lift and Drag in paraview | SamerAli | ParaView | 1 | May 16, 2013 12:51 |
[ANSYS Meshing] Lift & Drag Meshing Techniques | tylerplowright | ANSYS Meshing & Geometry | 6 | May 2, 2012 23:53 |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 10:38 |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 27, 2007 23:38 |
