July 3, 2015, 06:17 |
SAS unphysical wiggles
Jose
Rep Power: 10 |
Dear all,
I am running a simulation of the flow around a bluff body. I am using the SAS-SST k-w turbulence model. In the report below from ANSYS and in many other papers, it is recommended to use a discretisation scheme for the momentum with low numerical dissipation: Central Difference (CD) or Bounded Central Difference (BCD). http://www.ansys.com/staticassets/AN...ing-models.pdf BCD is more stable and should be the preferable option. However, when there is a unphysical delay in the formation of eddies, it is recommended to use the even less dissipative CD (this is my case). As CD is less stable, it can produce unphysical wiggles and in theory you should always monitor the solution to ensure that wiggles are not dominating the solution. Here comes my question. I am using the CD scheme for the momentum discretisation, how can I differentiate the physical eddies with the unphysical wiggles? Or, how can I determine if the wiggles are dominating the solutions? Thank you in advance for your help, Jose |
central difference, sas, unphysical wiggles |
FSAS coefficient in k-omega SST SAS model | vkrastev | OpenFOAM Running, Solving & CFD | 9 | October 25, 2018 08:09 |
Will the unphysical pressure in several cells of micro-channel influence the result? | red.yxg | OpenFOAM Running, Solving & CFD | 0 | June 8, 2015 09:57 |
Dynamic Lagrangian - wiggles on unstructured grid | Atoom | OpenFOAM Running, Solving & CFD | 6 | April 7, 2014 06:07 |
SAS model | Itsme | Main CFD Forum | 0 | October 24, 2008 10:34 |
Small Wiggles in Hydrofoil Pressure Distribution | James Date | CFX | 13 | May 18, 2005 04:30 |
