November 17, 1999, 15:53 |
Reference needed: Laminar backward facing
Hi:
I need a reliable reference to compare a code for the (1)- Laminar backward fcaing step and (2)- Laminar shear layer, two parallel streams with different speeds. If any one is aware of a good reference, I would be appreciated if he/she can share his info with me. Thanks. Mohammad |
November 18, 1999, 01:39 |
Re: Reference needed: Laminar backward facing
Hi
you try to see this page it presents some results for a turbulent flow over a backward facing step. you could also get some useful references. http://ta.twi.tudelft.nl/isnas/report94-24/isrep2.html Hafid |
November 18, 1999, 09:07 |
David Gartling, "A test problem for outflow boundary conditions --- flow over a backward-facing step", International Journal for Numerical Methods in Fluids 11:953-967, 1990.
Armaly, Durst, Pereira, Schonung. "Experimental and theoretical investigation of backward-facing step flow", J. Fluid Mech. 127:473-496, 1983. |
November 19, 1999, 15:14 |
Thanks for the info.
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
