Source code for Convection-diffus & Navier stokes
Old   October 1, 2008, 11:30
Default Source code for Convection-diffus & Navier stokes
vishal
I am solving a 2D convection diffusion equation and also navier stokes using Finite Volume method. I would like to know whether any source codes are available for them. I saw some source codes like Open foam, overture, NaSt3DGP etc from the CFD online links. I would like to know out of all these source codes or others which one should I use (that is reasonably efficient, easy to comprehend and takes reasonably less computational time) to solve my problem.
Kindly help in this regard.
Thanks in Advance.
Vishal
Old   October 2, 2008, 04:27
Default Re: Source code for Convection-diffus & Navier sto
sudhakar
hi, I suggest you to refer the codes provided by Peric. See the appendix section of the book by the Ferziger and Peric for how to access the codes. It is written in fortran and really very simple and self-explanatory..
Old   October 2, 2008, 11:56
vishal
Thanks a lot for the reply. But i use C and not Fortran... so any C codes available
Vishal
Old   October 7, 2008, 06:49
x-flow
I will suggest the use of OpenFVM:
http://openfvm.sourceforge.net/
It is very easy to comprehend just as the codes of Peric. It is coded in C and not fortran. It can be easily compiled in both Windows and Linux. It also has a reference manual which describes the numerical methods used.
Note: For solving 2D convection/diffusion and navier-stokes, activate the calculation of u,v,p and T. Being T the solution of the convection/diffusion equation. This is done by changing the parameter (.par) file. For a quick start, look the tutorial in the reference manual.
Old   October 7, 2008, 12:00
Vishal
Hi x flow,
Thanks a lot for the suggestions. I will download it and if I have any queries I need your help.
Thanks in advance.
Regards
Vishal Nandigana
Navier Stokes code in C++ Naga Potluri FLUENT 3 February 12, 2012 18:45
1D Navier Stokes Code CFDtoy FLUENT 0 May 20, 2004 10:27
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
