August 17, 2015, 21:48 |
CFX transient wall temperature
Hello All,
I have tried to search quite a bit to figure this out with literature and other forum discussions but I haven't had any success and I hope someone could really help me out. The problem is fairly simple: I have an enclosed domain (all walls - a very skewed and distorted triangle if you will) with a fluid inside it. It is being heated from one of the walls (sort of the hypoteneus - heat flux in 7000W/m2) for a duration of 1 hour (3600s at 0.05 timestep size). I am trying to solve for two things: 1) Buoyancy driven fluid motion and convection. This was easy and it was resolved quite nicely. I got a small animation for the velocity and temp contours. 2) There is a 2 inch block of aluminum sitting at another wall that needs to be heated by the fluid as the Al block cannot be in contact with the heat source wall. - How do I solve this one? 2a) Do I have to physically build a 2 inch block on to the geometry? If so, will that regarded as a second domain? 2b) If not, can I specify a wall thickness of 2 inches and the material as Aluminum? 2c) What type of boundary condition will I be assigning to the wall? (Heat Flux or Heat Transfer Coefficient?) 2d) If I am to assign it as 'Heat Transfer Coefficient', will I have to manually calculate it to incorporate the 2 inch thickness? Finally, in CFX Post, I am not able to make a chart of Temperature profile at a wall vs. time (XY transient) because the drop down menu labeled 'Location' is blank.
Adi. |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 04:03 |
wall temperature setting | nianqi | CFX | 0 | October 16, 2006 06:53 |
