obstacle question of nasavof2d
Old   October 7, 2008, 23:53
Default obstacle question of nasavof2d
stock
hi, i recently use nasavof2d to solve tank draining problem,and i want to set obstacle cells in the fluid.so i set beta(i,j)=-1.0 in obstacle cells by hand in subroutine setup,as if (XI(I).LE.0.40.AND.(YJ(J).GE.1.0.AND.YJ(J).LE.2.0) )
BETA(I,J)=-1.0 then running the fortran codes,when i used tecplot to display the result,i found velocity appeared in the obstacle cells.. i don't understand.
thanks,stock
Old   October 8, 2008, 01:38
Default Re: obstacle question of nasavof2d
a
it's not strang,
an example: assume solid is parallel to x-axis and you have no-slip condition on wall, then we set u-velocity of fictitious cells (in fact first row of obstacle, wall) equal to -1* u-velocity of cell in vicinity of wall,
i.e., for a bottom wall: u(i,j) = -1.* u(i+1,j) (e.g. for i=1)
Old   October 8, 2008, 03:42
stock
thanks, but in the solavof2d,obstacle cells set only in the subroutine meshst as i do in the nasavof2d.it don't need to reset u-velocity or v-velocity in vicinity of obstacle wall. it only set u-velocity or v-velocity in boundary conditions.
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Question on heat tranfer from an obstacle into fluid ekh95 FLOW-3D 0 June 3, 2009 18:09
Turbulence : rectangular obstacle in a pipe sam FLUENT 2 June 25, 2007 23:53
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
