October 20, 2015, 04:30 |
Aerofoil C.O.G
Rep Power: 10 |
Hi, I'm wondering how i would calculate the centre of gravity of an aerofoil, given it's x and y co-ordinates?
Thanks, Dale. |
October 20, 2015, 10:00 |
Rep Power: 18 |
To compute the center of gravity you will need the mass or density distribution of the airfoil. If you have the mass distribution then the formula can be found in most basic calculus books. See this page for more information as well:
https://www.grc.nasa.gov/www/k-12/airplane/cg.html |
October 20, 2015, 12:16 |
Kaya Onur Dag
Rep Power: 13 |
interesting..
in applications this would be useless because I don't think you can find a cross-section filled with the same material. usually inner side of the 2d shape is empty. having said that, to answer your question if you assume that the density distribution is the same, if I am not mistaken you should be able to find the center of gravity by something like if the airfoil has camber, it might be a bit tricky to calculate in this way. if the airfoil is symmetric, is 0. |
October 21, 2015, 08:15 |
Rep Power: 10 |
Hi, thanks for this, this is very helpful. My aerofoil is cambered. I have a series of upper and lower co-ordinates. In both the equations, for x_i and y_i, should i use the upper or lower parts of the x and y co-ordinates? Also in the equation for y_COG, should it be x_upper and x_lower? Thanks again for the help. Dale. |
October 21, 2015, 14:52 |
Matt
Rep Power: 17 |
Do you not have a CAD software available to you? That would be the easiest way to find this value.
Also, you are looking for a centroid not a center of gravity unless you have mass properties defined as well. http://www.intmath.com/applications-...troid-area.php |
October 21, 2015, 15:57 |
#6 | |
Kaya Onur Dag
Rep Power: 13 |
again, if its cambered I don't think you can apply this from the shelf. |
[Other] Meshing Layers over Aerofoil | poloding-along | OpenFOAM Meshing & Mesh Conversion | 5 | April 4, 2014 10:41 |
2D Aerofoil with rotating cylinders - Help & Advice! | Bluejay | OpenFOAM | 1 | December 31, 2012 04:40 |
Fluttering or Vibrating aerofoil | Alan | FLUENT | 1 | January 13, 2006 03:06 |
Meshing an aerofoil with a plain flap | Fatou | FLUENT | 0 | November 15, 2005 14:24 |
2D Aerofoil Simulation | StudentAndrew | CFX | 10 | October 28, 2005 16:15 |
