December 14, 2008, 16:50 |
Riemann solver
There are many approximate Riemann solvers for Godunov type schemes. Given the capability of modern computers, why not just stick to the exact iterative Riemann solver? Are there other issues concerned such as stability?
Shuo |
December 16, 2008, 05:04 |
Re: Riemann solver
The exact Riemann's solver is more prefarable from a lot of points of v.. also from stability (you could find Prokopov articles and etc.), the main - the exact R.S. is a solution of the Fluid Structure Interaction problems, it is always stable, a problem - the exact R.S. for arbitrary state eq. (it is necessary to use numerecial integration for rarefaction wave)
December 17, 2008, 19:36 |
Re: Riemann solver
In that case why bother using TVD I thought it was to minimise spurious oscillations near flow discontinuities.
Shuo |
July 7, 2009, 13:21 |
Nishant Kumar
Hi Shuo,
I am dealing with the same problem. Were you able to figure it out? Reply me at babuu.nishu@gmail.com Thanks |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 07:45 |
Riemann solver | Eddy | Main CFD Forum | 0 | January 8, 2010 04:13 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Mashing Problem? | ji | CFX | 2 | April 4, 2002 05:03 |
