ISAAC
Old   December 16, 2008, 15:10
Default ISAAC
Alex
Hi, Ehsan!
On 20 Aug 2008, you posted a message as follows:
" I want to run ISAAC on windows Xp but i can't . . . when i build the program it write these message : io.obj : error LNK2001: unresolved external symbol _FDS@24 Debug/main.exe : fatal error LNK1120: 1 unresolved externals Error executing link.exe. "
Did you eventually fix the error? If yes, then which way?
I have bumped into the same symbol _FDS@24 while linking the code with Compaq visual Fortran 6 on Windows XP.
Alex
Multiblock grid file to solve in ISAAC Kishore Main CFD Forum 1 October 27, 2009 04:26
ISAAC Source File Question jonny_b Main CFD Forum 3 July 2, 2009 11:59
ISAAC ehsan Main CFD Forum 0 August 20, 2008 04:10
ISAAC code compilation, Linux aurel Main CFD Forum 0 November 22, 2007 02:19
who had used the ISAAC code? Martin J Main CFD Forum 0 September 1, 2003 22:50
