January 17, 2007, 09:36 |
nasa rotor 67 or 37 geometry
dear all I need the geomtry of nasa rotor 67 or 37 test case for validation of code. i would be thankful to you
January 17, 2007, 14:44 |
Re: nasa rotor 67 or 37 geometry
What code are you testing? Have you got results of experiment testing of rotor 67 and 37?
January 19, 2007, 01:18 |
Dear Ivan
I am using Fluent 6.2. and I dont have experimental results of nasa rotor 67 etc. I would be grateful if any body can help me regards sam |
January 19, 2007, 05:45 |
If you fined - write me, please: ivanklok@mail.ru
January 20, 2007, 05:16 |
sure
June 12, 2007, 00:37 |
Hi:
You can find geometry of Nasa Rotor 37 and experimental results at NASA-TP-1659 NASA-TP-1337 NASA-TP-1338 AGARD-AR-355 (http://ftp.rta.nato.int/public//PubF...AGARDAR355.pdf) Can you tell me , which software you are using to generate blade geometry, actually i have blade parameters but don't know how to use these parameters to generate blade geometry. Thanks |
June 12, 2007, 03:54 |
I am using Gambit/G Turbo
can you send me that file on my email address. |
June 20, 2007, 05:01 |
yes: send me your email
June 27, 2007, 04:29 |
#9 |
June 27, 2007, 06:30 |
#10 |
where do u live? I will send within couple of days.
June 30, 2007, 07:57 |
#11 |
I want the axial compressor blade geometry (naca 67 rotor) .so thanks
July 5, 2007, 10:21 |
#12 |
You can get geometry for Rotor 67 here:
http://ntrs.nasa.gov/archive/nasa/ca...1990001929.pdf The table starts on page 18. Does anyone have any geometric data for stators tested with Rotor 67 (or 37)? I'd be grateful if anyone who does can post up the links. |
August 20, 2007, 06:33 |
#13 |
Also, Rotor 67 and Stator 67A geometry available here:
NASA Technical Memorandum 88929 Unsteady Flows in a Single-Stage Transonic Axial-Flow Fan Stator Row Michael D. Hathaway See pages 182 to 188. http://ntrs.nasa.gov/archive/nasa/ca...1987007372.pdf |
August 23, 2007, 16:51 |
NASA 67 STAGE GEOMETRY COMPATIBLE
#14 |
Does anyone have the goemtry of NASA stage 67 already in any alectronic format? IGES format would be very useful. Although any format compatible with Fluent/Gambit woul be good as well.
February 11, 2008, 03:55 |
#15 |
how to use this data to model rotor in ProE or any other 3D cad software or in AutoBlade of NUMECA?
Thanks. |
February 24, 2008, 11:00 |
#16 |
please send for me geometry of nasa rotor 67 or 37
August 18, 2008, 01:00 |
#17 |
please send me the geometry of NASA rotor 67
October 2, 2008, 10:04 |
#18 |
It will be great if you could send me the NASA Rotor 67 geometry and blade profiles.
thanks |
December 23, 2008, 18:35 |
Re: nasa 37 geometry
#19 |
Please send me NASA rotor 37 profile...
July 27, 2009, 04:27 |
NASA stage 35
#20 |
Rep Power: 16 |
Dear all, anyone have the model of NASA stage 35 or any reference paper on that , kindly hope that u can share with me about that
NASA Rotor 37 Boundary Condition Problems | Dom | FLUENT | 1 | March 27, 2012 07:00 |
nasa rotor 67-blind case for cfd | sam | FLUENT | 2 | April 3, 2011 15:04 |
can i get geometry of nasa rotor 67 from fluent | alex marshall | FLUENT | 0 | March 27, 2006 04:20 |
NASA Rotor 67 Geometry | alex marshall | Main CFD Forum | 2 | March 27, 2006 04:02 |
NASA rotor-xxx grid file | cfd_fan | Main CFD Forum | 0 | January 12, 2005 19:22 |
