particle-air mixing
Old   December 11, 1999, 07:04
Default particle-air mixing
Günther Hasse
I have to design a "turbulator" which could distribute a vertical incoming stream of fly ash particles with a size range between 1 - 250 micron (from a feeder) uniformly across a rectangular horizontal duct (approx. 800x1000). The air is flowing from left to right in the duct at a speed of approx 20 m/s. The design is for an experimental facility.
Could anyone refer me to existing "turbulators" or suggest devices which could be tested numerically using CFD ?
Regards Günther
Old   December 15, 1999, 10:23
Default Re: particle-air mixing
Patrick Godon
I saw that you got no answer. I don't know anything about turbulators or devices, but if you need any help with the modeling of the two-phase flow to model the particles-air fluid, then let us know. I can give some very good references on that, and I can try to answer some of your specific questions.
Patrick
Particle tracking in Mixing tank zhang.limin FLUENT 0 November 12, 2010 20:23
Air & water mixing problem praveenkumar FLUENT 0 April 15, 2010 02:14
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
air particle simulation software kong Main CFD Forum 0 February 11, 2006 22:33
