January 31, 2009, 01:05 |
pls solve this error
hi
while solving the wave tank problem i am getting the error like this.can any body help me to solve this Error message from graphics function Update_Display: Invalid subscreen specification - Subscreen 'bottom' is above 'top' -- Will use (-1, +1, -1, +1) -- problem thanking you sekhar |
January 31, 2009, 10:03 |
Re: pls solve this error
What software? Which wavetank problem?
February 1, 2009, 00:32 |
hi i am using fluent software. i modelled the water tank using gambit while opening with fluent it was fine .if i display that mesh file i am getting the error like this.
Error message from graphics function Update_Display: Invalid subscreen specification - Subscreen 'bottom' is above 'top' -- Will use (-1, +1, -1, +1) -- thanking you |
nonNewtonian viscosity model | mhassani | OpenFOAM Programming & Development | 5 | January 7, 2013 09:27 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
