Analysis of a halogen lamp in ANSYS
Old   February 6, 2009, 00:38
Default Analysis of a halogen lamp in ANSYS
Vinayak
I want to study the heat flow pattern generated by a halogen lamp kept in a closed chamber. I am giving the convection and radition on the halogen lamp and the surface of the chamber. Also I applied the heat generation on the halogen lamp in ANSYS. But I do not find any temperature increase on the surface of the chaber.
Can anybody tell me what is the correct method to do it. Also does ANSYS has the capability of doing such analysis?
Old   February 7, 2009, 22:44
Default Re: Analysis of a halogen lamp in ANSYS
Ahmed
1- What bc have you assigned to the surface of the chamber 2- When you ask "does ANSYS has the capability of doing such analysis?" what do you mean by that? ANSYS has a bunch of programmes and products. Which specific programme are you using? 3- What analysis technique are you using?
Old   February 9, 2009, 06:52
Vinayak
Actually I have designed a circular halogen lamp and a rectangular chamber of 3 mm thickness and size 200*220*100 (W*L*H). I am using ansys multiphysics. I am using radiation B.C. on the surface of the lamp and on inner surface of the chamber. Also I have given heat generation on the halogen volume.
But in the solution it shows that the halogen is generating the radiation but the radiations are not going on the surface of the chamber. Because of this there is no rise in the temperature of the chamber whereas the halogen is at around 500 to 800 degree centigrade temperature.
Can u please tell me what boundry condition shall I apply and what mistake I am making.
Steady level flight airfoil analysis using ANSYS CFX v12 flutter CFX 21 March 29, 2016 03:51
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Transient Thermal Analysis in Ansys Workbench khurram1 ANSYS 0 November 22, 2010 02:40
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
analysis of pump flow in ANSYS prakash CFX 3 September 10, 2008 06:13
