ADI implicit doesn't converge
Old   February 12, 2009, 19:34
Default ADI implicit doesn't converge
George Papadakis
Hi guys
I am making an compressible euler code using FVM on structured grids (i am going unstructured in the future,but i take things step by step.).I have made an explicit version of the code,and now i am working on the implicit version.
I am using first order Roe scheme for temporal discretisation and 2nd order MUSCL Roe/Van leer scheme for spatial.I solve the system using DADI.The problem is that the implicit version doesn't converge even with cf lower than one(the explicit code runs at larger cfls!!!)
It's obvious that i am doing sth wrong...So basically i am asking for any ideas of what is going wrong..
I have tested the implicit code in 1-d shock tube and it converges with max CFL 5.
Is there a chance that additional dissipation is needed even though i use upwind schemes??
Can it be that adi si causing the instabilities??
Thank you very much.
PS. I know that i am giving little information for you to point me the errors.I am just asking for any ideas of what might be wrong.People with greater experience might have in mind something
Old   February 15, 2009, 08:25
Default Re: ADI implicit doesn't converge
George Papadakis
I am putting some code here,if anyone hcan help
!!This is the I-direction sweep(the same is for J)
Subroutine sweepi
use Variables
use Param
use Matr
use grid
Implicit None
real,allocatable :: VARP(:,:,:,,VARM(:,:,:,
real :: UV(3),E,ATMP(4,4),NLOC(3),UB(3),TMP(4,4),TMP1(4,4) ,ATMP1(4,4)
integer :: i,j
real :: P1,P2,c1,c2,dens1,dens2,Vt,U1(3),U2(3),p,c,dens
allocate (VARP( 1:NMAXI,1:NMAXI,NMAXK,5),VARM(1:NMAXI,1:NMAXJ,NMAX K,5))
UB=0
Vt=0
NLOC=0 ! First order temporal
do i=1,NMAXI-1
do j=1,NMAXJ-1
VARP(I,J,1,1:5) = UP(I ,J,1,1:5)
VARM(I,J,1,1:5) = UP(I-1 ,J,1,1:5)
NLOC(1:2) = NORMALI(I ,J,1:2)
!JACIP
dens = VARP(I,J,1,1)
UV(1:3) = VARP(I,J,1,2:4) / VARP(I,J,1,1)
E = VARP(I,J,1,5 ) / VARP(I,J,1,1)
P = (GAM-1)*(VARP(I,J,1,5) -0.5*VARP(I,J,1,1)*(UV(1)**2+UV(2)**2))
c = sqrt(GAM*p/VARP(I,J,1,1))
call conv_jacob2(nloc,dens,UV,E,ATMP)
JACIP(i,j,1:4,1:4) = AREA(I,J,1)*ATMP (1:4,1:4)
!JACIM
dens = VARM(I,J,1,1)
UV(1:3) = VARM(I,J,1,2:4) / VARM(I,J,1,1)
E = VARM(I,J,1,5 ) / VARM(I,J,1,1)
P = (GAM-1)*(VARM(I,J,1,5) -0.5*VARM(I,J,1,1)*(UV(1)**2+UV(2)**2))
c = sqrt(GAM*p/VARM(I,J,1,1))
JACIM(i,j,1:4,1:4) = AREA(I,J,1)*ATMP (1:4,1:4)
!ROE
dens1 =VARP(I,J,1,1)
dens2 =VARM(I,J,1,1)
U1(1:2) =VARP(I,J,1,2:3)/dens1
U2(1:2) =VARM(I,J,1,2:3)/dens2
P1 = (GAM-1)*(VARP(i,j,1,5) -0.5*dens1*(U1(1)**2+U1(2)**2))
P2 = (GAM-1)*(VARM(i,j,1,5) -0.5*dens2*(U2(1)**2+U2(2)**2))
c1 = sqrt(GAM*p1/dens1)
c2 = sqrt(GAM*p2/dens2)
call roejac2 (dens1,dens2,c1,c2 ,U1,U2,P1,P2,NLOC,Vt,ATMP)
JACIROE(i,j,1:4,1:4) =AREA(i,j,1)*ATMP(1:4,1:4)
enddo
enddo
deallocate (VARP,VARM)
End Subroutine sweepi
!the construction of the implicit operator
Subroutine impl2(i,j,nodi,nodj)
use Variables
use Param
use Matr
use grid
Implicit None
integer,intent(in) :: i,j,nodi,nodj
real :: AI(4,4),II(1:4,1:4),W(1:4,1:4)
AI=0
II=0
II(1,1)=1
II(2,2)=1
II(3,3)=1
II(4,4)=1
AI(1,1)=VOLUME(i,j)/DTT(i,j)
AI(2,2)=VOLUME(i,j)/DTT(i,j)
AI(3,3)=VOLUME(i,j)/DTT(i,j)
AI(4,4)=VOLUME(i,j)/DTT(i,j)
LOWERI(NODI,1,1:4,1:4 ) = 0.5*( JACIM(i,j,1:4,1:4) - JACIROE(i,j,1:4,1:4) )
LOWERJ(NODJ,1,1:4,1:4 ) = 0.5*( JACJM(i,j,1:4,1:4) - JACJROE(i,j,1:4,1:4) )
UPPERI(NODI,1,1:4,1:4 ) =0.5*(-JACIP(i+1,j ,1:4,1:4) - JACIROE(i+1,j ,1:4,1:4))
UPPERJ(NODJ,1,1:4,1:4 ) =0.5*(-JACJP(i ,j+1,1:4,1:4) - JACJROE(i ,j+1,1:4,1:4))
DIAGI(NODI,1,1:4,1:4)=0.5*(-JACIM(i+1,j,1:4,1:4)+JACIP(i,j,1:4,1:4)+JACIROE(i ,j,1:4,1:4) +JACIROE(i+1,j,1:4,1:4) ) +AI(1:4,1:4)
DIAGJ(NODJ,1,1:4,1:4)=0.5*(-JACJM(i,j+1,1:4,1:4)+JACJP(i,j,1:4,1:4)+JACJROE(i, j,1:4,1:4)+JACJROE(i,j+1,1:4,1:4))+AI(1:4,1:4)
end Subroutine
Old   July 8, 2009, 13:27
Nishant Kumar
Nishu is on a distinguished road
Can you please send me the 1D code for shock tube problem at babuu.nishu@gmail.com? I need it for my research.
Thanks alot
Nishant
Nishu is offline   Reply With Quote
Implicit Reimann solvers harish_0689@ Main CFD Forum 0 September 18, 2011 13:09
HELP !In relaxtion factor converge is taken or not MANOJ KUMAR FLUENT 5 September 22, 2005 04:16
Converge problem for multiphase flow Jen FLUENT 4 July 20, 2005 16:52
how implicit is implicit? Joe cool Main CFD Forum 7 July 16, 2004 11:10
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 14:04
