Modelling indoor air flow field - Outlet Static Pressure |
April 4, 2016, 17:26 |
Hello dudes!
I am a begineer in CFD, and I am simulating a retangular enclosure enviroment with forced convection of air. The geometry domain has just one inlet and one outlet. My boundary conditions are: at the inlet I set the velocity and the turbulent parameters. At the walls I set temperature constant. At the outlet I set the Static Pressure. My great doubt is about the static pressure at the outlet. My intention is that this outlet simulate na entrance of na air-conditioning system, and my inlet would be the exit of the air-conditioning system. The question is: Would this outlet pressure be a negative pressure? Or must I set this static pressure as zero? What would be a better practice? If someone already worked in a problem like this, please help me. Thank you very much |
Compressible Flow Pressure Outlet Back Flow | okstatecheme | OpenFOAM Running, Solving & CFD | 1 | March 21, 2018 08:11 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Pressure outlet in two-phase flow in horizontal 2D channel | AlmostSurelyRob | Main CFD Forum | 0 | November 17, 2010 07:32 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
Guessing the static pressure needed to produce flow rate | jpo | FLUENT | 0 | June 22, 2009 12:53 |
