blocking and meshing 2 cylinders with dif diameter
Old   May 31, 2016, 08:14
Default blocking and meshing 2 cylinders with dif diameter
Andrei Bogdan
andreibac is on a distinguished road
Hi guys,
I need to do a project for my university and focusing with some problems in ICEM. I'm trying to create 2 cylinders with different diameter, all good but when I want to block and then mesh them I'm confronting with problems.
Anyone here who can help me and explain how to block them.
Please see the picture, the first one is without blocking, then in the second i tried to block but after association I get the same result, which is wrong. Tried all solutions but the same result..
I would appreciate any help from you.
Thank you
andreibac is offline   Reply With Quote
Blocking for hexa meshing of diffuser augumented wind turbine zeeshu Mesh Generation & Pre-Processing 0 February 10, 2016 17:37
Blocking for hexa meshing of diffuser augumented wind turbine zeeshu ANSYS Meshing & Geometry 1 February 10, 2016 16:23
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator Crank-Shaft ANSYS Meshing & Geometry 5 January 17, 2016 23:29
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp Crank-Shaft ANSYS Meshing & Geometry 0 January 11, 2013 05:48
[ICEM] Hexa meshing blocking problem fergal ANSYS Meshing & Geometry 0 June 28, 2011 10:01
