June 13, 2016, 11:05 |
Residuals in a Transient valve analysis.
Rep Power: 9 |
Hi there,
I am running a transient simulation for flow through a valve. I have the timesteps set to 1e-05s for 100 timesteps which I hope should give me a reasonable solution. However, I am at a slight loss as to whether the results look right or not. Attached are two images, the first has the residual drop for against iterations for a selection of timesteps. The second shows the outputs of a selection of monitoring points. (Please excuse the slightly pixelated image, a quick paint hash job was necessary to get the images uploaded). Transient Residuals 1.jpg Transient Residuals 2.jpg Transient Outputs.jpg Is the fact that the residuals seem to be going unstable over time necessarily a bad thing in a transient solution? The monitoring points seem (simulation is still running at this point) to be converging on reasonable values. Any input would be much appreciated. Cheers |
pumplinx, residual, transient |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 06:01 |
Transient Thermal Analysis in Ansys Workbench | khurram1 | ANSYS | 0 | November 22, 2010 02:40 |
Large Valve Flow Analysis - Inflation Problem | sercan85 | ANSYS Meshing & Geometry | 2 | June 1, 2010 14:02 |
Transient periodic analysis & Boundary conditions | Michele | FLUENT | 0 | March 25, 2006 16:07 |
