how can i find a data file on naca0012
Old   August 10, 2016, 08:05
Default how can i find a data file on naca0012
hashem0091 is on a distinguished road
i want data such cl , cp , mach contour on naca0012
compressible 2d euler equation
id appreciate if any one can help me
hashem0091 is offline   Reply With Quote
Old   August 10, 2016, 10:29
agd
agd is on a distinguished road
Are you really looking for Mach contours in incompressible flow? That might explain why you are having problems finding results. Assuming that you misspoke concerning the Mach contours, have you searched the internet? There is a wealth of data out there. You may have trouble finding an Euler run to compare to but you should find good agreement if you focus on high Reynolds number cases at moderate angles of attack (prior to massive separation). You can also look for the book by Abbott and von Doenhoff, 'Theory of Wing Sections'. Here is link to get you started
http://naca.central.cranfield.ac.uk/...report-824.pdf
agd is offline   Reply With Quote
Old   August 10, 2016, 12:41
realy sorry for that , i mean compressible, i want to validate some results on this airfolil , i need to compare such this quantities , that would be great if there is a data file..
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
