October 18, 2016, 10:12 |
Convergence Requirement
Arnab Mukherjee
Rep Power: 9 |
I am extremely new to CFD. This question might be silly, but in several solving methods we need to iterate the scheme at each time step multiple times to make it converge and then move on to the next one (like Roe Solver). But, the schemes like Maccormack, Richtmeyer, Lax Friedrichs etc. don't require such per time step iterations to attain convergence. So, I would like to know that why do they not require it?
This question came to my mind when I was coding the Sod's Shock Tube Problem in Matlab and simultaneously in Fluent. |
October 18, 2016, 10:51 |
Filippo Maria Denaro
Rep Power: 71 |
I suggest starting to learn explicit and implicit time integration for simple one-equation model. Then, you can understand their application in the case of a system of coupled equation. Use a good textbook of CFD or numerical analysis.
October 18, 2016, 11:01 |
Rep Power: 11 |
Hi, are you maybe simply confused about explicit and implicit schemes? Maybe you can catch up on this by looking it up on google or your favourite CFD book
if a scheme is explicit, as FTCS or Lax-Friedrich, it can evaluate the next point only based on known values, so no iteration is required. if you're new to CFD, it is also helpful if you keep finite difference and finite volume schemes distinguished when comparing scheme properties if you want to avoid confusion (you listed a mix) have fun! |
October 18, 2016, 11:02 |
Rep Power: 11 |
oops too slow, sry
October 18, 2016, 11:08 |
Arnab Mukherjee
Rep Power: 9 |
Thank You for the reply. Now, I do understand why this is happening.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
