Wanted buoyancy constants in k-epsilon model
Old   February 4, 2000, 04:50
Default Wanted buoyancy constants in k-epsilon model
grig
Generation of turbulence due to buoyancy sometimes is included in k-e model "... +c1(eps/k)(1-c3) g mu / (rho sigma _ h) * d rho/d z +... ", where c1=1.44, g=9.8, etc. Please who can tell typical (Mach=0) values two constants c3, sigma_h and appropriate references?
Thank you. Grigory.
Old   February 5, 2000, 18:21
Default Re: Wanted buoyancy constants in k-epsilon model
Jens Wyrwa
As far as I understood, you address the C3 empirical constant, that appears in the epsilon equation of k-epsilon turbulence model. C3 is connected with the buoyancy influence on turbulence. (your formula-fragment does not match with formulations I know)
Rodi (Turbulence Models and Their Application in Hydraulics 1980) discusses it and suggests a value of 0.8 connected wich an appropriate formulation of flux Richardson number. Recent investigations I read about (Sanders et al. Int. J. Heat Mass Transfer No.4(1997), Char+Hsu Int. J. Heat Mass Transfer No.12(1998), Hwang+Chiang J. Fluids Eng. Dec.1995 ), leave it out or set it to zero.
I need to find out about this problem myself. So if somebody in this forum knows more, please be so kind to send a note.
Jens Wyrwa
buoyancy augmented k-eps model mabinty OpenFOAM Running, Solving & CFD 7 April 19, 2019 07:51
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Wall functions for near wall treatment : k - epsilon model fivos Main CFD Forum 4 April 27, 2011 07:44
Problem in Buoyancy Model? dhrubo CFX 3 June 5, 2010 05:32
How to choose the buoyancy model? ben Phoenics 2 April 8, 2002 04:04
