Experimental data for validation of a 2D conv-div nozzle in mach range 0.2-2.0
Old   January 18, 2017, 04:56
Default Experimental data for validation of a 2D conv-div nozzle in mach range 0.2-2.0
DDikeshorn
DDikeshorn is on a distinguished road
Dear reader,
I am looking for experimental data of a (non)adiabatic air flow trough a 2Dconverging-diverging nozzle in the Mach range of around 0.2 at the inlet to 2.0 Ma at the outlet for validation of a Boundary Layer code.
Most important are the velocity profiles and displacement thickness for the validation of my code. I am using the CS-model described by Cebeci and Smith from their 1974 book [1].
After searching, the only valuable thing I found was a plot of 'measured' displacement and momentum thickness in a nozzle in a NASA report by McNally [2]. However, the measurements did not go far beyond the throat, and no velocity profiles were available.
Does anybody now a nozzle case with experimental data for air in this Mach range? Thank you in advance.
[1] Analysis of turbulent boundary layers; Cebeci, T.; Smith, A.M.O.; 1974
[2] FORTRAN Program for calculating compressible laminar and turbulent boundary layers in arbitrary pressure gradients; McNally, D.; 1970
DDikeshorn is offline   Reply With Quote
experiment data, nozzleflow2d, validation
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
non-dimensional analysis in Fluent Endee FLUENT 8 September 7, 2005 16:16
