CFD for temerature measurement
Old   February 20, 2000, 03:29
Default CFD for temerature measurement
William Blake
I have proble in calculating temperatures on the surface of vehicle at hyperonic mach numbers. At subsonic mach numbers, it is a practice to cosider body as an adiabatic surface. This is certainly not valid at hypersonic Mach #. Can any one has successfully done these calculations. Any refence would be of immense help.
Old   February 20, 2000, 03:51
Default Re: CFD for temerature measurement
Bob Anderson
Sounds like you don't have enough information to solve the problem yet. Is your vehicle reaching thermal steady state? If so, where is the heat being drawn off to if it is not essentially an adiabatic surface?
Bob
Old   February 20, 2000, 17:32
clifford bradford
if you assume the body is heat soaked then can't we use the adiabatic bc as a best guess. otherwise there is no reasonable way to specify thermal bc without doing conjugate heat transfer. i guess you'd need some first guess on a heat transfer distribution.
Old   February 22, 2000, 13:16
John C. Chien
(1). The adiabatic condition certainly can be used in the analysis, unless one is concern about the real condition. (2). Depending upon the Mach number, (at Mach 4, things would be all right), the viscous heating eventually will exceed the melting point of the material at much higher Mach number. (3). At Mach 8, the real gas effect will set in, and at even higher Mach number, the chemical reactions in the boundary layer must be included. (4). At extreme Mach number, special silicon tiles must be used, like those used on the space shuttle. (5). Or, very thick carbon composite material can be used by releasing the heat through burning of the material. In that case, mass transfer in boundary layer will have to be considered. There was a book on hypersonic viscous boundary layer published in 60's. There are also more recent books on hypersonic flows, by Anderson? Look into AIAA journals, you should be able to find the right information you need.
CFD Wiki - We Need More Help Jonas Larsson Main CFD Forum 13 September 13, 2005 17:36
CFD job and salary? Mingyong Main CFD Forum 11 January 2, 2001 06:15
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
Since Last June John C. Chien Main CFD Forum 3 July 12, 1999 09:38
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
