flow calculations with RANS 2eq models
Old   March 7, 2000, 10:50
Default flow calculations with RANS 2eq models
Andreas Abdon
I'm working on flow calculations with RANS 2eq models and I'd just like ask : the term d/dx(-2/3*densit*k) is dropped from the momentum eq's quite often in the literature without any comments? Why? Is this generally an accepted approximation or is it because people want to make their simulations more stable? Some codes have included this term into the pressure gradient (giving a modified pressure) but I guess creates a special treatment when pressure is used elsewhere. Any hints on this anybody?
Regards
Andreas
Old   March 7, 2000, 10:58
Default Re: flow calculations with RANS 2eq models
Dr. Hrvoje Jasak
As far as I know, it's almost standard to treat this term together with the pressure, and some people (including myself) don't even bother taking it out afterwards (small relative to the pressure level). The thing is that for stability (at least in collocated FV codes) it requires exactly the same treatment as the pressure gradient and it is easiest just to add the terms together. I have never seen this cause any trouble; if anyone has, I'd be interested.
Hrv
Old   March 7, 2000, 11:38
Andreas Abdon
Thanks, Hrvoje! Is the incorporation of this term into the pressure also "standard procedure" when using nonlinear eddy viscosity or explicit ASM models?
/Andreas
Old   March 8, 2000, 06:09
Dr. Hrvoje Jasak
Yup, I use it always, even for Reynolds stress. It has never caused me trouble in non-linear k-e, but i'm not sure whether they are really worth the effort.
Have fun,
Hrv
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
velocity calculations in mass flow inlet boundary condition montazer1012 FLUENT 1 October 18, 2010 03:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
