Natural Convection CFD code
Old   March 20, 2000, 15:01
Default Natural Convection CFD code
stephen
I would like to know which code can handle natural convection problems real well. Or is this a problem any code can do easily? I am looking at Fluent, Maya(ESC), and CFdesign as three code options. Which of the three is robust in handling this type of analysis?
Old   March 20, 2000, 15:15
Default Re: Natural Convection CFD code
David
You could also add STAR CD to your list.
regards
David (ICEM CFD Engineering UK)
Old   March 20, 2000, 20:00
mahesh prakash
Hi Stephen,
As far as I know pure (turbulent) natural convection cannot be handled easily by any of the commercial codes running on a pressure velocity coupling algorithm such as SIMPLE, SIMPLER or SIMPLEC. Since natural convection is a temperature gradient driven phenomenon one might need a temperature coupling as well. This has been looked into by Prof. Phil Wood of McMaster University (I will dig up the paper and let you know about the details).
If one uses Multi gridding techniques the problem could be alleviated to some extent. So look for multigridding options in the commercial codes.
Cheers
Mahesh
Old   March 21, 2000, 18:32
Carlos Vilela
Hi Stephen. If your interest is only in natural/mixed convection problems, I think that you have to look at some particular features if is or not supported by the software that you are buying. In my point of view, i would choose the software that present most of the following aspects: 1) FVM based 2) If use the natural/mixed convection equations [1] 3) If have temperature dependent fluid properties 4) Easy to geometric modelling 5) If is possible to implement user subroutine
Actually, i am using Ansys to simulate other kind of fluid flow problems, but once i looked in the manual and i didnīt find if the temperature-velocity coupling, Bousinesk assumption, is already implemented in fluid flow equations, i think that there is other coupling method or you have to write your subroutine and use ir as source terms in momentum equations. Among the softwares that i have used, i choose Fluent or Phoenics.
Good luck
Carlos Vilela
[1]Burmeister, "Convective Heat Transfer"
Old   March 27, 2000, 15:30
turboguy
Still, If I have a chance for recommandation of you cfd code, then my recommadation is STAR-CD.
A couple of years ago, I had been used the Fluent. However It was really hard to get the converged solution in natural convection.
turboguy
Old   April 2, 2000, 16:56
Phil Gresho
If the flow is laminar, and if you want ACCURATE results, there is probably no better code than FIDAP, a finite element code within the Fluent family.
Old   April 25, 2000, 06:24
Dimitri Nicolopoulos
You might want to have a look at our FE fully coupled (vel-p-thermal) solver. M-Implict/AcuSolve. It has great capabilities to solve such problems www.mcube.fr
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
about cfd code, free or for payment John M Main CFD Forum 6 September 15, 2003 08:59
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 18:43
CFD JOBS and Expected Salary.... Noel Harrison Main CFD Forum 11 November 22, 2000 07:15
OOP for CFD code Jongtae Kim Main CFD Forum 26 October 20, 2000 06:11
