3D data-set
Old   April 18, 2000, 23:00
Default 3D data-set
Sebastien Perron
I'm working on the development of a new finit volume method. This method can use structured and non-structured grid in 3D. To validate my code I need an experimental (or numerical) solution of a 3D laminar flow. I'am interested in solving the 3D liddriven cavity flow.
thanks
Old   April 25, 2000, 20:14
Default Re: 3D data-set
frederic Felten
hi,
Go check the directory ftp.springer.de inside pub/technik/peric You might find some examples cases of liddriven cavity flow! Good luck in your investigations! Sincerely,
Frederic Felten
Old   April 25, 2000, 20:26
frederic Felten
If you cannot find anything on ftp.springer.de, You may also wanna check:
"Solution of the Navier-Stokes equations for a driven cavity" B.D. Semeraro,...
Publisher: [Washington, D.C.? : National Aeronautics and Space Administration, 1991]
Pubs./Microfiche Number:
NAS 1.26:188008
Sincerely,
Frederic Felten
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 05:45
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
mode of a data set m malik Main CFD Forum 4 December 20, 2003 09:18
Where I could find the book or the data set. boling Main CFD Forum 0 November 21, 2003 12:47
