June 11, 2000, 03:44 |
BCs in staggered grids
I am a CFD newbie and am attempting to model incompressible 2D flow in a cylinder with SIMPLE and a staggered grid. I have two rather basic questions: 1) How do you handle the no-slip condition at the wall with a staggered grid? Do you interpolate? 2) What is an appropriate velocity BC at the outlet for a specified pressure drop across the cylinder? Obviously I cannot specify the velocity itself, but what do I do with those outer grid points? Thank you in advance for your help - Katherine Daru |
June 15, 2000, 15:07 |
Re: BCs in staggered grids
Hi, Katherine,
1) How do you handle the no-slip condition at the wall with a staggered grid? Do you interpolate? 1a): By using the no-slip condition in calculating the momentum flux through the wall when we derive the finite-difference equation for the near-wall nodes. 1b) Yes, in a sense. 2) What is an appropriate velocity BC at the outlet for a specified pressure drop across the cylinder? For example, du/dx=0. Mathematically, you can even prescribe u (as far as continuity is satisfied) but du/dx=0 is more realistic. It is not that easy to specify the pressure drop. Specyfying the flow rate is more convenient. Rgds, S. |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
central, upwind, UTOPIA, staggered grids | Maciej Matyka | Main CFD Forum | 2 | July 8, 2004 14:02 |
problem related to staggered grids | zhu | Main CFD Forum | 10 | October 27, 2001 22:30 |
Multidomain method with non-overlapping, non-matching grids with staggered arrangement | franck bertagnolio | Main CFD Forum | 1 | April 25, 2000 15:40 |
Staggered grids for compressible flow? | Frank Muldoon | Main CFD Forum | 4 | October 23, 1998 09:50 |
