Spiral Jet Mill
Old   June 28, 2000, 04:37
Default Spiral Jet Mill
Kargl Karl
I'm working on the simulation of jet milling. Jet mills are size reduction machines which accelerate the particles to be ground in a rapid fluid stream, effecting a comminution either by means of mutual collision or impact against a target. Jet mills are employed for superfine to colloid size reduction. Jet mills achieve jet speeds of up to Mach 2. However, it should be noted that immediately after the particles are fed to the mill chamber, the jet speed drops significantly.
I made various runs with different conditions(initial, boundary and different meshes) and with different CFD programs.
So, my problem is to verify this runs. Did anyone know someone who is making similiar simulations or are there any testcases for such a problem ?
Thank You,
Kargl Karl
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 09:34
determination of jet front Fred CFX 5 February 11, 2007 12:01
method to determine jet front Fred Main CFD Forum 0 February 8, 2007 13:15
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
