How to insert tables (P,T) for properties on STARCCM+
Old   April 30, 2024, 04:55
Default How to insert tables (P,T) for properties on STARCCM+
Alessio
Fluidalessio is on a distinguished road
Hi guys, I am working with supercritical water and would like to include the pressure and temperature dependency in the properties via the tables that STARCCM+ provides. I have never done this and any advice on this is welcome. In my problem I have pseudocritical temperature crossing so for temperature I need a lot of values as the properties vary a lot with it, for pressure I have no idea how many values I should take (I know the code does a linear interpolation in this case). The system inlet pressure is 23.5 MPa and the system is in overpressure (fluid expansion causes hydraulic resistance). How should I set up these tables? In what order do I put the columns? I have looked a bit in the guide but would like more precise information on this. Thanks in advance!
Fluidalessio is offline   Reply With Quote
3D Insert modelling in Mold Flow Dan Rößler Main CFD Forum 0 December 20, 2005 06:37
