High-order scheme and grid
Old   September 14, 2000, 22:41
Default High-order scheme and grid
z.zeng
I am coding a Linear Stability Analysis for fluid dynamic problem, and therefore a genernalized eigenvale problem A x=lamda B x must be solved. The dimension of A and B is (4xNJxNK)^2.(NJ and NK is number of grid in y and z direction). Due to the limitaion of memory, NJxNK can only be up to 30x30, but it seems too coarse for my calcutation.
My quesation is
(1) If a higher-order difference scheme (e.g. 4-order)is adopted in stead of my present 2-order scheme, the problem caused by coarse grid can be remedied?
(2) I remeber that a paper mentioned that a non-homgious grid would reduce the accurate of high-order scheme. I read it several years ago, and can not find it again now. What is your suggestion on a homgious or non-homgious grid?
(3) Could you suggests a good high order difference scheme to me with corresponding literature?
Your advises and suggestions on any above questions are highly appreciated.
Thanks in advance.
Zeng
Old   September 15, 2000, 18:05
Default Re: High-order scheme and grid
frederic felten
Check out the following publication:
http://landau.mae.missouri.edu/~vasi...high-order.pdf
Sincerely,
Frederic Felten
Old   September 16, 2000, 06:48
Chidu
It is a good idea to use a spectral type discretization if you are really limited by a coarse grid. This will give you much better results if your focus is to obtain very accurate eigenvalues.
With finite-difference you can use arbitrarily higher-order approximations which is obviously limited by the number of grid points you have. There is a paper in the SIAM Journal which gives an algorithm to generate coefficients for arbitrary order of accuracy finite-difference scheme. The author escapes my memory, I will look it up and repost.
chidu...
Old   September 17, 2000, 20:32
Z.Zeng
Thanks you all for your kind help.
Chidu mentioned paper seems very interesting, we wish you can find it.
zeng
Old   September 18, 2000, 06:25
K.S.Ravichandran
Chidu & Zeng
You may look up Fornberg's paper "Generation of Finite-Difference Formulas on arbitrarily spaced grids", Math. Comp. V51, N0184, p699, 1988
Ravichandran
Old   September 18, 2000, 10:12
Chidu
Exactly, Ravi. This is the paper. I was on vacation and did not have access to the info. Thanks.
regards, chidu...
Old   October 14, 2000, 13:10
ajay singh
please guide me for using higher order scheme for les
Oscillations in Results and Residuals Freeman FLUENT 27 December 18, 2010 13:09
Compact scheme for nonuniform grid? Dong Main CFD Forum 3 July 1, 2008 23:44
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 16:31
Upwind Converged while Higher Resolution Not! Sherry Clark CFX 4 October 20, 2004 23:27
2nd order boundary condition for QUICK scheme Jafarnia Main CFD Forum 0 February 25, 2004 09:03
