SORET EFFECT
Old   October 9, 2000, 07:29
Default SORET EFFECT
vijay pargaonkar
I would like to collect the names of persons who are analysing "Soret Effect".
By analysing I mean,
1) Analysis which will show when the soret effect is significant.
2) Analysis which is carried on a transport phenomenon in which mixture of gases is the fluid.
3) Analysis which will forecast the degree of separation of gases due to this effect.
Thanks in advance,
with regards Pargaonkar Vijay C.
Old   October 10, 2000, 10:08
Default Re: SORET EFFECT
Chuck Leakeas
Pargaonkar,
I am studying the Soret effect on a SiH4-H2 chemical system inside a chemical reactor. I am investigating the effect that the Soret effect has on the deposition rate of silicon on a wafer surface for the manufacture of microelectronics. So far I have not found any contribution to the deposition rate at 1333.15 K. I will continue my work and keep you posted if you are interested.
Chuck
Old   October 10, 2000, 10:42
vijay pargaonkar
Dear Chuck Leakeas,
That is interesting.
Nice to hear that, you are studing SORET EFFECT. BTW, for silicon epitaxy ie (SiH4 and H2 as career gas) Soret effect is normally negligible. That is what is finding from my numerical experiments. Of course it does depend on the specific reactor you are simulating.
I am very much interested in getting data for this effect specially when it is a gasesous mixture. Hope you will find significance of Soret Effect during your experiments. Looking forward to hear from you on my mail id.
pargaonkar vijay
Old   October 13, 2000, 09:53
I. Dotsikas
Hi Chuck,
The Sorret Effect is only important when you have large temperature gradients AND when the dimensions of your Spacies vary very much; (like WF6 and H2). In this case you should use the multikomponent thoerie of diffussion, too. Under normal circumstances you donīt have any problems with such effects. This effect may be quite important in LPCVD/CVD or in combustion. To tell the truth I have never seen any other application of these theories in an other subject. By the way, do you have great teperature gradients? It doesn't seen to be the case.
SiH4 Deposition bei 1335K.(!!!) I've never heard of that bevor. Do you have any special application? Do you use any Dopants?
cu
Jiannis
Old   October 13, 2000, 16:51
Chuck Leakeas
Hello Jiannis,
I am looking at a normally impinging jet onto a wafer surface. The mixture in the incoming jet is 298.15K and the wafer is 1333.15K. The separation distance is 0.08 meters so there is a strong temperature gradient in front of the jet. So far I have not been able to detect a difference in the deposition rate even at 1533.15K. It is very possible that I will show that the Soret effect is negligible over a wide range the temperatures and inlet concentrations for this particular reactor design and operating conditions. Good luck in your research.
Chuck
Old   October 18, 2000, 00:23
vijay pargaonkar
Dear chuck,
Your problem under investigation seems interesting. can provide me the geometry and boundary conditions?
I will try it for differnet epitaxies. I agree with Mr Dotsikas. He has raised valid points. (Mr Dotsikas thank you.).
One more thing I send you two mails. Both of them bounced back. Can you please provide me your alternative email id.
with regards pargaonkar vijay
What is Soret effect? Chuck Leakeas Main CFD Forum 9 October 19, 2016 09:39
Can Flow-3D solve the Joule-Thomson effect? seasoul FLOW-3D 8 December 21, 2011 00:01
Thermodiffusion or Soret effect Chuck Leakeas Main CFD Forum 2 July 24, 2002 02:42
Soret effect Chuck Leakeas Main CFD Forum 1 February 25, 2001 11:08
Soret effect Chuck Leakeas Main CFD Forum 0 November 23, 1998 14:53
