KIVA2
Prev Previous Post   Next Post Next
Old   October 31, 2000, 04:28
Default KIVA2
hush
Dear CFD folks,
I'm a new KIVA user. I have KIVA 2, and ITAPE also. Now, I'm in a trouble. I ran the code with the ITAPE and looked at some results with Tecplot. But, I found something wrong in the solution. Velocity and other scalar quatities didn't look coupled together. Velocity contours were looking good(?) themselves. but, density, temperature, pressures etc. seem to be solved only in j=1 as if I set the problem using sector mesh option(Mesh is 360deg.). I checked the input data(CYL, JSECTR, etc), but I found nothing wrong. I think someone touched somewhere in the source code I have.
So I'd like to run other problems to check if my code has been changed or not.
If anyone can send me ITAPE or OUTPUT, CLEAN KIVA 2 SOURCE CODE, that'll be very helpful to me.
thanks
