November 9, 2000, 06:20 |
BCs of hyperbolic Shallow Water Equation
I am a graduate student who studies hydrodynamics. I want to solve hyperbolic 2-D shallow water equations (1 continuity eq, 2 momentum eqs) by Finite Volume Method using limiter with unstructued grid. For 1-D Saint-Venant equation, when flow is subcritical we specify 1 boundary condition (discharge or flow velocity) at upstream end and another one(water depth) is calculated from characteristic equation at upstream end. I got to know it becomes complicated when the problem is 2D. The characeristic line is no longer expressed in 2D plane. In 2D shallow water equation the unknowns are u, v, h (u,v=x,y velocity; h=water depth). For subcritical flow two variables(u, v) are known and one variable(h) us unknown at inflow boundary. How should I determine h ?
November 20, 2000, 11:15 |
Re: BCs of hyperbolic Shallow Water Equation
You might find the answer by looking at a few demonstration cases describing the main details of how PHOENICS , finite-volume code, has been taught to deal with Shallow Water Equations for the sub- and super-critical flows to simulate:
Regards Sergei Zhubrin |
November 20, 2000, 22:33 |
Thanks for your reply. I visited PHOENICS sites that you said. But the demonstration cases also used fixed flux at inlet boundary,ie. all (3) boundary values are imposed at inlet boundary by Dirichlet type. Anyway, I greatly appreciate your answer.
Regards Kang, S. K. |
November 21, 2000, 04:16 |
If one introduces the terms representing the elevation of bed above arbitrary horizontal datum as a momentum sources, the depths at the inlet and outlet planes can be calculated as a part of the solution without imposing the fixed inlet fluxes.
The corresponding changes of BC are straightforward to derive and implement. Regards Sergei Zhubrin |
November 21, 2000, 21:20 |
Then, can you please send me the derivations of the terms for super- and sub-critical case privately.
Thanks for your reply. Regards Kang, S. K. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Vorticity in inviscid shallow water equations | sonsiest | Main CFD Forum | 0 | June 7, 2011 14:10 |
Problems with BCs in muliphase flow with water falling from a reservoir | Paul_l | FLUENT | 2 | March 11, 2011 04:59 |
Looking for "numerical methods for shallow water flows" book | novan tofany | Lounge | 0 | February 10, 2011 18:28 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
