November 22, 2000, 11:10 |
NUMECA Fine / Baldwin-Lomax Turbulence model
I'm simulating the flow in the diffuser of the impeller of a radial compressor with the NUMECA/Fine Turbo solver. I'm using the Baldwin-Lomax tubulence model. Has anybody some experiece with this turbulence model combined with this flow solver? If yes, can You tell me, for which range of the law-of-the-wall coordinate y+ at the first node from the wall You obtain acceptable results concerning total pressure losses? The manual gives ranges for k-epsilon models but none for Baldwin-Lomax.
Thank You for Your help! |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
turbulence model equation | Andy Chen | FLOW-3D | 4 | January 1, 2010 21:45 |
build your own turbulence model with buoyancy | Thomas Baumann | OpenFOAM | 11 | November 23, 2009 08:53 |
