Turbulent Fluctuations
Old   December 2, 2000, 10:45
Default Turbulent Fluctuations
Thomi
Hi there,
Have you got any suggestions for calculating the turbulent fluctuations/intensities for a time series? Is it the standard deviation of the mean? I appreciate any comments and suggestions. Many thanx,
Thomi
Old   December 6, 2000, 14:52
Default Re: Turbulent Fluctuations
Hallo
If your time series is steady then the fluctuating velocity (u') is just the instantaneous velocity (u) minus the mean velocity (U). Where the mean is calculated from a given time interval. the turbulent intensity (TI) is usually defined as some estimation of the small scale (or turbulent) velocity scales, non-dimensionalized with the large scale velocities. You can pick different velocity scales depending on the problem you have. Usually, the turbulent velocity scale is the root mean square (urms) where urms = sqrt(1/N * SUM(u'u')) where N is the number of discrete u' measurements and the large scale velocities is typically taken to be U.
Note this can be found in any book on Turbulence... (Lumley, Hinze, ...)
Old   December 6, 2000, 16:39
Thomi
Hi Hallo,
Thanks a lot. that helps for a start. so there is no standard deviation involved?
Old   December 7, 2000, 09:34
Hallo
If you use the standard definitions ie. u=U+u' and the u'rms defined in the previous thread then the turbulent intensity is just the average variations from the mean velocity (or the standard deviation) normalized with the mean velocity.
(ie. u'rms is the standard deviation)
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
plotting turbulent fluctuations CML CFX 1 January 6, 2008 17:21
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
