January 10, 2001, 23:24 |
what is SINUM
what is SINUM, I am searching an article in SINUM, but I don't know what it is, a journal or proceedings?
January 11, 2001, 01:41 |
Re: what is SINUM
(1). There is always a place called "library", where you can find anything published. (2). Try to make friend with the library first, if you will be doing research in the future.
January 11, 2001, 05:20 |
Re: what is SINUM
thanks for your help, certainly I go for library first, but there's no SINUM. then I go to yahoo, there's no SINUM also. then I asked my advisor, he said he knew SIAM. but I am not sure. so I put my question here. however, when I visit the article's author's homepage, I found out that SINUM is the acronym of SIAM numer. anal., in the library, it always takes the latter form.
January 11, 2001, 04:53 |
A non-sarcastic answer
Please Ignore Chien's comment. This is just a person who should learn when to speak and when not to speak...
Anyway, I'm not too sure what SINUM is but when I do a Web search I come up with this... http://www.siam.org/journals/sinum/sinum.htm This is a relevent journal... I hope this helps.... |
January 11, 2001, 05:34 |
Re: A non-sarcastic answer
(1). Good answer. (2). His question helped you in gaining Internet search experience. (3). And my answer give you the courage to write the message. (4). If we do this everyday, it might be a good idea to provide a "fast library service" home business? Just a joke. (5). It is obvious that none of us read such a high level journal. (If I don't read this journal, then you don't have to read it either. )
