Numerical Diffusion in 1D Advection-diffusion solution
Old   June 29, 2020, 16:20
Default Numerical Diffusion in 1D Advection-diffusion solution
Nabeel Khan
nabeelk04 is on a distinguished road
I used Finite Volume method and switched diffusion term off, but still I'm getting false diffusion in numerical solution for 1D case.
I understand it's occuring due to truncation error, I also tried using very small conntrol volume and very small time steps but still the error in solution is very high. I used 2nd order accurate discritization as suggested by Patanker in Numrical Heat Transfer and Fluid Flow
Please guide me how to reduce the error.
Please look at the video of simulation: https://drive.google.com/file/d/1nrl...ew?usp=sharing
nabeelk04 is offline   Reply With Quote
Old   June 29, 2020, 16:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Could you write exactly your scheme? The plot shows a monotone and diffusive behavior typical of a first order accurate scheme
FMDenaro is offline   Reply With Quote
advection-diffusion, fvm, numerical diffusion
Numerical Diffusion Ford Prefect Main CFD Forum 16 March 31, 2020 15:38
Numerical solution Saikat_FM Main CFD Forum 0 March 25, 2015 22:27
Time unit in finite volume solution for diffusion problem. alpha2beta Main CFD Forum 0 June 30, 2010 02:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
