multiple inlets
Old   January 19, 2001, 14:13
Default multiple inlets
Bob Haase
Hi, I have a duct with multiple inlets and one outlet. I know the maximum allowable airflow through the duct. What I would like to know is the pressure loss through the duct. I don't know the inlet flows or the outlet pressure. The inlets stick out into a room that is at atmospheric pressure.
I am using CFD2000 (now called Storm, I think). My choices of BCs are inlet: pressure, velocity, or mass flow; outlet: pressure, zero gradient, or mass flux.
Any ideas?
thanks, Bob
Old   January 19, 2001, 20:57
Default Re: multiple inlets
John C. Chien
(1). The total pressure loss in a duct will be a function of the mass flow rate. So, you will have to measure it first. (2). The loss prediction is among one of the most difficult task to do. It also requires a relatively fine mesh so that the flow field can be computed correctly. (3). If you really need the loss number accurately, testing is the way to go.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Is it possible to have multiple velocity inlets in your model boundarylayer FLUENT 0 June 5, 2010 02:29
Multiple inlets problem Jeff Main CFD Forum 2 August 17, 2005 10:48
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
