2D-vertical density current model
Old   January 28, 2001, 09:00
Default 2D-vertical density current model
Stone
I want to simulate density current in the sea or river by vertical 2D model. How should I solve this one? Is it adequate to solve Euler equation and advection-diffusion equation? Then, how should I treat free surface ??
Regards.
Old   February 6, 2001, 10:06
Default Shallow Water Equation
Patrick Godon
Have you heard of the shallow water equation?
IN this case you solve for the thickness (height) of the layer and for an incompressible flow. This allows you to simulate the surface waves (gravity waves) in the sea, atmosphere, etc...
IS the 2D vertical the (z,x) plane, where z is the vertical (direction of the gravity is -z) and x is the latteral dimension (horizon e.g.).
Then basically you solve one equation for the velocity in x and one equation for h (the vertical thickness of the fluid).
If this is what you are looking for, then I'll give you some references.
Cheers, Patrick
Old   February 7, 2001, 13:41
Default Re: Shallow Water Equation
Kang, Seok Koo
Well, I think the shallow water equation is not a good choice for solving such a problem. There may be some misunderstanding to whom read your statement. The shallow water equation does not take into account the vertical acceleration, so hydrostatic pressure distribution along vertical direction is assumed. Therefore it is difficult to simulate density current which propagates x-, z- direction using it (x-, y- direction is possible since it is horizontal 2-D model).
Boussinesq model gives constant density daol FLUENT 4 June 12, 2018 09:28
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Bubble Number density model CFDUSERIN CFX 1 November 9, 2011 09:50
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
