February 10, 2001, 13:39 |
whistling problem from radiator
I encouter a whistling problem from the radiator (with straight fin) in a compacotr machine after the fan reach a certain speed. Can anyone provide some insight of the problem to me. I will appreciate the help. Thanks!
February 13, 2001, 18:50 |
Re: whistling problem from radiator
(1). You need to identify the source of this whistling if you are trying to avoid it. (2). Was it from the fan itself? or from the radiator fin? or from the inside of the radiator? or from the casing? (3). Do you think that it is related to CFD ?
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
