Computation of velocity
Old   March 12, 2001, 04:28
Default Computation of velocity
Mikael Tushensson
I'm solving system of transport fluid equations for density (n) and for momentum (nu) with sources and electromagnetics equation for that sources. My computational domain consists of regions with zero density and some regions with zero density can appear in the process. The question is, how to apply advection across the entire system, i.e. how to define the velocity in the zero density regions.
Old   March 12, 2001, 13:40
Default Computations in space??
Bubba
Interesting. My question would be is Continuum modelling valid for gases with near "zero" density. Maybe you have to define regions where it is valid, solve using continuum equations there, set up boundary conditions, and then solve in the regions where continuum approximations aren't valid using say the boltzmann equation...
I think the Navier-Stokes equations are usually valid for a Knudsen Number greater than 0.001
Kn= (mean free path of molecules) / (characteristic length)
Maybe there are other techniques. If there are, I would be interested too...
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
Difference b/W vol. avg. velocity and superficial velocity mwtengr FLUENT 1 March 5, 2011 08:20
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
