treatment of cavitation
Old   April 18, 2001, 07:28
Default treatment of cavitation
manfred krueger
i am working on solving the euler equations for water (water is given by tait equation of state with a simple cavitation model: if the pressure drops below a certain value pressure is set to this value). the equations are solved by a modified method of characteristics. Because of the cavitation model the speed of sound turns to zero in cavitated regions and the equations are no longer hyperbolic. i tried various formulations but all remained unsufficient. does anybody have an idea how to treat this sort of problem?
manfred
Old   April 18, 2001, 09:46
Default Re: treatment of cavitation
Buvana
can you give some more details of your work. Do you solve the energy equations also. Also, could you please tell which cavitation model you are using
Thanks Buvana
Old   April 18, 2001, 11:20
manfred krueger
the equation of state for water is based on the tait model. the predicted pressure is not allowed to fall below the cavitation pressure pc, although the density can continue to decrease below its critical value rhoc:
p= B((rho/rho0))**gam - 1) + A if rho>rhoc
pc otherwise the numerical method is based on extrapolating values for half of the time step via characteristics to the cell edges and then solving linearized riemann problems. on my mind the speed of sound plays a major role in this region of cavitation and i do not know how to treat this problem or to calculate speed of sound, because with this model csound equals zero and the riemann problem can not be solved.
Old   April 24, 2001, 10:02
Srinivasan Arunajatesan
Hi!
We have done some extensive work on cavitation. Modeling cavitation by the method you are using will work only if some form of state equation relating the speed of soud to mixture pressure is provided. The experimental result suggests that this relationship is actually harmonic - the speed of sound in the liquid medium drops drastically even for small volume fractions of gas in the mixture. We have derived an equation of state that reproduces this relationship.
Once this relatioship is used, formulating the Reimann problem is a piece of cake. Although most formulations to date do not include the energy equation in them (ie. they assume that each phase is incompressible in itself, but account for the variation in speed of sound in the mixture) the compressible formulation is a direct extension of this. We have formulated this also. However, it is a lot messier than the incompressible formulation.
If you are interested in the incompressible formulation, you can look up our papers :
Simulations of Cavitating Flows using Hybrid Unstructured Meshes : To appear in Journal of Fluids Engineering, June 2001, Vol 123.
Earlier refs :
AIAA-99-3330
AIAA-97-2081
If you want electronic copies of any of these papers I can send them to you. Let me know.
Srinivasan Arunajatesan Research Scientist CRAFT Tech. Inc. Dublin, PA. www.craft-tech.com ajs@craft-tech.com
compressibility and cavitation!! xhliu1 Fidelity CFD 2 June 27, 2005 17:16
compressibility and cavitation!! xhliu1 Siemens 11 March 16, 2005 07:19
Cavitation Simulation by CFD Liu, L. CFX 2 November 29, 2000 13:50
Cavitation Simulation by CFD Liu, L. Siemens 2 November 1, 2000 21:51
Cavitation Simulation by CFD Liu, L. Main CFD Forum 7 November 1, 2000 21:26
