Simulation of fluid flow through nozzles
Old   May 9, 2001, 06:02
Default Simulation of fluid flow through nozzles
Spiegel
Has someone got any idea/experience on this topic? Where can I find related information? Any CFD software, which is able to model a free jet of liquid (or even in air)? Tipical values: 200-1000bar, 20(!)-150micron orifice diameter.
Old   May 9, 2001, 12:33
Default Re: Simulation of fluid flow through nozzles
John C. Chien
(1). If it is a free jet, then why not use the analytical solutions? You can find the solution in the "boundary layer theory" book by Schlichting. (2). In the book, there is a chapter on Free turbulent flows;Jets and wakes. (3). For round jets, it turns out that the analytical solution is the same because the viscosity and eddy viscosity are constant for laminar and turbulent flows, respectively. (4). So, the analytical solution of a free jet can be applied to any size jets.
Old   May 9, 2001, 16:32
Astrid
What is the purpose of your research? What do you want to spray? What are the inlet and outlet pressures?
Old   May 10, 2001, 03:30
Spiegel
Hello, Astrid! It's a sort of cutting application in a new kind of way, see: www.synova.ch. (I'm working on a PhD thesis in this field.) Thus, my aim is to get a non-cavitating "coherent" jet as long as possible. I mean the breakup length should be long even when using very small nozzles (down to 20microns in diam.) Typical water pressure is between 100-1000bar, the jet is exiting into the atmospheric air. The water-jet will not necessarily cut by itself, but a laser beam is injected in it. The jet acts like an optical waveguide plus a cooling agent, the laser cuts. So, it's like a focus-less, chilled laserbeam. But, as the jet gets disturbed the light scatters out of the beam and efficiency is lost. Cavitations result in lower cut quality. The final aim is a better nozzle design for this application. Synova has a lot of experimental knowledge on micro water-jets, but I want to put the whole stuff onto theoretical basis. Thanks, S
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
rerun with same flow field, different fluid props Tim Phoenics 0 March 3, 2004 14:51
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
