June 20, 2001, 03:04 |
Turbulent viscosity
Hi.
I have made a simulation upon a rectangular box. Inlet in one end, and outlet in the other end. Inlet vel. is approx. 20 m/s. There are no temperature differences. The problem is that I get a too high turbulent viscosity (the turbulent/laminar viscosity ratio is limited to approx. 10^5). I first considered that it could be due to a too fine grid combined with a "coarse" turbulent model (k-e model), so I tried with a coarser grid. No effect. I have also tried other models (RS, LES) but it did not do the trick (well, the LES did with a good initial guess). Q: Is it true that there are problems with combining a fine grid with a "coarse" turbulent model? Q: Do anyone have suggestions as to solve the high turbulent viscosity problem? I would appreciate comments to the two questions. Cheers Christian |
June 20, 2001, 08:36 |
Re: Turbulent viscosity
In fact turbulent/laminar viscosity ratio=10^5 is typical value. Don't worry. For instance, in my numerical simulations of supersonic turbulent jets flowing into atmosphere I got maximum dynamic turbulent viscosity approx 0.5 Pa*sec (molecular vis is about 1e-5 Pa*sec). I used Menter's k-w model and got good agreements with experiments.
Alexey. |
June 21, 2001, 05:09 |
I would think that the more turbulent the flow is, the higher the ratio. And I guess that supersonic can be considered very turbulent, and a high ratio could be expected. My case on the other hand is not that turbulent, and I am just surprised that the ratio is that high, and I am afraid that it might contaminate the solution. I can see that the convergence is more stable when I lower the inlet vel. Do you have any suggestions what to do about a potentially too high viscosity ratio ?
Christian |
June 21, 2001, 13:38 |
(1). Take the flow over a flat plate as a test case. (2). Run some cases of flat plate flow, refine the mesh, and check the results against the test data.
June 23, 2001, 22:04 |
Try to check the mesh quality, by means of the distributions and values of the y-plus and y-star. Good luck, |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES | Marvin | Main CFD Forum | 6 | December 4, 2009 11:08 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
